The dbo, or database owner, is a user account that has implied permissions to perform all activities in the database. Members of the sysadmin fixed server role are automatically mapped to dbo.The dbo user account is frequently confused with the db_owner fixed database role. The scope of db_owner is a database; the scope of sysadmin is the whole server. Membership in the db_owner role does not confer dbo user privileges.
Tim,As mentioned in the below link, "Remember, the user name and schema name must be the same if this user is going to own data." -- Point #14Adding database-authenticated logins to a SQL Server database:http://resources.arcgis.com/en/help/main/10.2/index.html#//002q0000002m000000Instead of trying to match the username with the Default Schema assigned by Microsoft SQL Server (which is dbo)....you simply need to match the 'Default Schema' with the username ( if username is X--> the default schema should be X as well)If a Login has been granted "sysadmin" privilege, it automatically becomes a DBO and its schema is taken as 'dbo'.NOTE: This is same for both DBO-Schema and SDE-Schema geodatabases.
ログインすると、投稿したり、更新をフォローしたりできます。初めてですか?無料アカウントを登録しましょう。
