gp.XYTolerance = "0.001 METERS" gp.XYResolution = "0.0005 METERS"
Too bad you can't set tolerances
is there any loss of data using the REPAIR GEOMETRY Tool?
The output of my thesis is an area and I used this tool sometimes, that's why it would be good to know,
if the created area is smaller than the area which could be created without using this tool?
a quick answer .... redo the calculation for area etc in a new field in the table ... best test
This has been a helpful thread. The Integrate geoprocessing tool took care of self intersections which could not be removed by the Repair Geometry tool. In my case it was set very low - at 0.01 feet. I would think setting this properly depends on how tight or loose the self intersections are. This was with version 10.2.2 and a file geodatabase polygon feature class.
