Is there a way to automatically fill such holes which aren't really holes?
Thx in advance!
Or for the case being shown...
This Expand/Shrink sequence can be used to get rid of inner inclusions and exterior fiddly-bits as well. You can repeat the above overwriting the temporary grids, It is an alternative to pointing at the screen and saying get rid of that bit
We use the Fill tool. Spatial Analyst Tools > Hydrology > Fill
For a vector, a handy trick is to use the Union geoprocessing tool with only one input and the 'allow gaps' option disabled. It is however a bit temperamental.
You could use the Con tool
How would this be implemented Steve? is there some way to look for containment?
Many thanks! Exactly what i needed:)
Glad it worked.
