//if (GeometryUtil.polygonSelfIntersecting(intersectGeom as Polygon)){ geometryService.simplify([intersectGeom], new AsyncResponder(simpResult, null, spatialRelat)); function simpResult(item:Object ,spatialRelat:String):void{ var simpGeoms:Array = item as Array; queryFeaturesGraphical(simpGeoms[0] as Polygon, spatialRelat, configSpatialSearchLayers[(cboSearchLayerSpatial.selectedIndex < 0)?0:cboSearchLayerSpatial.selectedIndex], "spatial"); } /*}else{ queryFeaturesGraphical(intersectGeom, spatialRelat,configSpatialSearchLayers[(cboSearchLayerSpatial.selectedIndex < 0)?0:cboSearchLayerSpatial.selectedIndex], "spatial"); }*/
private function intersectResults(spatialRelat:String):void { geomArr = []; var graLayBufferAC:ArrayCollection = graphicsLayerBuffer.graphicProvider as ArrayCollection; var graLayAC:ArrayCollection = qFeatLayer.graphicProvider as ArrayCollection; var intersectGeom:Geometry; if (graLayBufferAC.length >0){ var gra:Graphic = graLayBufferAC[0] as Graphic; intersectGeom = gra.geometry; queryFeaturesGraphical(intersectGeom, spatialRelat, configSpatialSearchLayers[(cboSearchLayerSpatial.selectedIndex < 0)?0:cboSearchLayerSpatial.selectedIndex], "spatial"); } else if (graLayAC.length >0) { intersectGeom = unionGeoms(resultsFeatureSet); if (GeometryUtil.polygonSelfIntersecting(intersectGeom as Polygon) || (intersectGeom as Polygon).rings.length > 1){ geometryService.simplify([intersectGeom], new AsyncResponder(simpResult, null, spatialRelat)); function simpResult(item:Object ,spatialRelat:String):void{ var simpGeoms:Array = item as Array; queryFeaturesGraphical(simpGeoms[0] as Polygon, spatialRelat, configSpatialSearchLayers[(cboSearchLayerSpatial.selectedIndex < 0)?0:cboSearchLayerSpatial.selectedIndex], "spatial"); } }else{ queryFeaturesGraphical(intersectGeom, spatialRelat,configSpatialSearchLayers[(cboSearchLayerSpatial.selectedIndex < 0)?0:cboSearchLayerSpatial.selectedIndex], "spatial"); } }else{ showStateResults(); showMessage("There is no result to intersect, please make a graphical or text search first.",false); } }
private function unionGeoms(featureSet:FeatureSet):Geometry { var graphic:Graphic; var retGeom:Geometry; var mPoint:Multipoint = new Multipoint; var poly:Polygon = new Polygon; var mPoly:Polygon = new Polygon; var mPolyL:Polyline = new Polyline; var rType:String; //Leonardo //For each polygon, tests if exists another that contains it. //If YES, the polygon will not included in union operation and it will added at polygonsToDiscard array. var aGraphic:Graphic; var polygonsToDiscard:Array = new Array; for each (graphic in featureSet.features){ poly = graphic.geometry as Polygon; if(graphic.geometry.type == "esriGeometryPolygon"){ for each (aGraphic in featureSet.features){ var aPoly:Polygon = aGraphic.geometry as Polygon; if(aPoly.extent.contains(graphic.geometry) && (aPoly.extent.center.x != poly.extent.center.x || aPoly.extent.center.y != poly.extent.center.y)){ // The polygon will not included in union operation. polygonsToDiscard.push(poly); } } } } //Leonardo: End of tests for discard polygons. for each (graphic in featureSet.features){ if(graphic.geometry.type == "esriGeometryPoint"){ mPoint.addPoint(graphic.geometry as MapPoint); rType = "point"; } if(graphic.geometry.type == "esriGeometryMultipoint"){ var mp:Multipoint = graphic.geometry as Multipoint var pnts:MapPoint; for (var p:int=0;p < mp.points.length; p++){ mPoint.addPoint(mp.points ); } rType = "point"; } if(graphic.geometry.type == "esriGeometryPolygon"){ poly = graphic.geometry as Polygon; //Leonardo //Consider only the rings that not coincide with any polygon ring on polygonsToDiscard array. var targetRings:Array = new Array; for (var m:int = 0; m < poly.rings.length; m++){ var polygonToDiscard:Polygon; var targetRing:Array = new Array; var targetPolygon:Polygon = new Polygon(new Array(poly.rings), poly.spatialReference); if (polygonsToDiscard.length > 0){ for each (polygonToDiscard in polygonsToDiscard){ var add:Boolean = true; if (targetPolygon.extent.center.x == polygonToDiscard.extent.center.x && targetPolygon.extent.center.y == polygonToDiscard.extent.center.y) { add = false; break; } } if(add){ targetRing[0] = m; targetRing[1] = poly.rings; targetRings.push(targetRing); } } else { targetRing[0] = m; targetRing[1] = poly.rings; targetRings.push(targetRing); } } //Leonardo: End of target rings selection. //Leonardo: Loop code below was changed to use targetRings array. for (var i2:int = targetRings.length - 1; i2 >=0; i2--){ var ringArray:Array = []; for (var j1:int = 0; j1 < targetRings[i2][1].length; j1++){ var mp2:MapPoint = poly.getPoint(targetRings[i2][0],j1) as MapPoint; mp2.spatialReference = poly.spatialReference; ringArray.push(mp2); } mPoly.addRing(ringArray); } rType = "poly"; mPoly.spatialReference = poly.spatialReference; } if(graphic.geometry.type == "esriGeometryPolyline"){ var polyl:Polyline = graphic.geometry as Polyline; for(var l:int=polyl.paths.length-1; l >= 0; l--){ var pathArray:Array = []; for (var j2:int = 0; j2 < polyl.paths.length; j2++){ var mp3:MapPoint = polyl.getPoint(l,j2) as MapPoint; mp3.spatialReference = polyl.spatialReference; pathArray.push(mp3); } mPolyL.addPath(pathArray); } rType = "line"; } if(graphic.geometry.type == "esriGeometryEnvelope"){ var ext:Extent = graphic.geometry as Extent; var pA:Array = []; pA.push(new MapPoint(ext.xmin,ext.ymin,ext.spatialReference)); pA.push(new MapPoint(ext.xmin,ext.ymax,ext.spatialReference)); pA.push(new MapPoint(ext.xmax,ext.ymax,ext.spatialReference)); pA.push(new MapPoint(ext.xmax,ext.ymin,ext.spatialReference)); pA.push(new MapPoint(ext.xmin,ext.ymin,ext.spatialReference)); mPoly.addRing(pA); rType = "poly"; } } var graphic2:Graphic = new Graphic(); var sfs:SimpleFillSymbol = new SimpleFillSymbol(); sfs.color = 0x0000FF; sfs.alpha = 0.2; var sms:SimpleMarkerSymbol = new SimpleMarkerSymbol(); sms.color = 0x0000FF; sms.style = SimpleMarkerSymbol.STYLE_CIRCLE; sms.size = 8; sfs.alpha = 0.4; var sls:SimpleLineSymbol = new SimpleLineSymbol(); sls.color = 0x0000FF; sls.style = SimpleLineSymbol.STYLE_SOLID; sls.width = 1; sls.alpha = 0.4; switch(rType){ case "point":{ graphic2.geometry = mPoint; graphic2.symbol = sms; graphicsLayerBuffer.clear(); graphicsLayerBuffer.add(graphic2); retGeom = mPoint; break; } case "poly":{ graphic2.geometry = mPoly; graphic2.symbol = sfs; graphicsLayerBuffer.clear(); graphicsLayerBuffer.add(graphic2); retGeom = mPoly; break; } case "line":{ graphic2.geometry = mPolyL; graphic2.symbol = sls; graphicsLayerBuffer.clear(); graphicsLayerBuffer.add(graphic2); retGeom = mPolyL; break; } } return retGeom; }
