Extract by mask worked perfectly well for 2 out of the 4 viewshed raster layers. The extract by mask fails everytime for the other two
There is a recently entered NIM on this, the workaround is to use the Clip_management tool.NIM078864 The Extract by Mask tool returns a 99998 error when clipping certain rasters.
The link that you posted is not functioning for me
I already tried using the clip management tool, the problem is that it does not create an attribute table and I need the breakdown of pixel counts to run stats.
