<Properties> <FileName>TransAndDist.msd</FileName> <OutputDir>d:\arcgisserver\arcgisoutput</OutputDir> <VirtualOutputDir>http://servername/arcgisoutput</VirtualOutputDir> <SupportedImageReturnTypes>URL</SupportedImageReturnTypes> <MaxImageHeight>2048</MaxImageHeight> <MaxRecordCount>1000</MaxRecordCount> <MaxBufferCount>100</MaxBufferCount> <MaxImageWidth>2048</MaxImageWidth> <IsCached>false</IsCached> <CacheOnDemand>false</CacheOnDemand> <IgnoreCache>false</IgnoreCache> <ClientCachingAllowed>true</ClientCachingAllowed> <CacheDir>d:\arcgisserver\arcgiscache\Delivery_TransAndDist</CacheDir> <SOMCacheDir>d:\arcgisserver\arcgiscache</SOMCacheDir> <MaxDomainCodeCount>5000000</MaxDomainCodeCount> <------------------------- <SchemaLockingEnabled>false</SchemaLockingEnabled> </Properties>
I just came across this problem with ArcGIS Server 10.1. The problem was I had a coded domain with 1000+ items on it (Street Name) which was applied to almost all the layers in the map. Removed the values and the error disappeared. I guess one could hide the column from the web service if required?
