The link to the code is not working. Can you please help? Also does the sample work with silverlight 3.2 API?
Looks like the links have been lost during forum migration :
A version of this sample is also available in the interactive SDK: Client Printing. This version is simplified (not multipage, no way to fix the scale) but the UI has been enhanced.
Thanks Dominique!
For some reason, when I chose print dialog and select a part of the map to print, it is not printing in the full page. This feature was working fine with earlier code when we were using Silverlight API 2.4. Would you know what could be the reason?
The sample is supposed to support Silverlight 3.2 since all live versions are using it.
I you can share a repro case, I'll look at it.
/Dominique
thanks very much Dominique
i use this sample in my application
it is simple and very nice
i cant use this sample with 2.4 api and silverlight 4,,, r there have any ver for
ログインすると、投稿したり、更新をフォローしたりできます。初めてですか?無料アカウントを登録しましょう。
