Is it possible to write the results of the reviewer tables to a newer version of ArcGIS( Ex. 10.3) however run the batch files against version 10.1? Thanks
Yes, you can validate a 10.1 geodatabase and have a 10.3 Reviewer workspace. Obviously, these have to be separate geodatabases. And you have to be using ArcGIS 10.3 Desktop on the client machine.
Thanks Michelle!!! Just a side note I talk with our GIS Administrators the other day and they want to roll full force with DR for Server and incorporate the dashboard through Flex/ Java script. Very exciting times over here in NC. Thanks for everything!
Do you mean that you want to run data reviewer against data in a 10.1 geodatabase, but write the results to a geodatabase created in 10.3?
