Greetings, My assignment is to create a custom tool on the tool bar using a python script.
import arcpy import pythonaddins class SuperBuffer(object): """Implementation for LYR.THM_WkrsSqMi (Button)""" def __init__(self): self.enabled = True self.checked = False def onClick(self): #Instantiate 'mxd' and 'df' as the Map Document and DataFrame variables mxd = arcpy.mapping.MapDocument("Current") print "'mxd' instantiated as Map Document variable." df = arcpy.mapping.ListDataFrames(mxd) print "'df' instantiated as DataFrame variable." #Create a Variable for the Layer you wish to Buffer. Later, you can get this dynamically #by using the 'arcpy.mapping.ListLayers' function to populate a Combobox with the layers #in your TOC layer = arcpy.mapping.ListLayers(mxd, "Layer you want to Buffer", df) print "'layer' variable instantiated." #Create a Variable to hold your Output FC so that you can add it to the Map after it #is created by the buffer tool. out_fc ="Layer_Buffer" print "'out_fc' variable instantiated." #Establish your Workspace workspace = arcpy.env.workspace = "C:\Temp\MyFileGeodatabase.gdb" print "Workspace set." #Run the Buffer Analysis on your Layer. You could also specify the distance and unit #of measurement dynamically using Comboboxes for Each and use the 'selection' for #those Comboboxes as the input. print "Buffering Layer..." arcpy.Buffer_analysis(layer, workspace + "\"" + out_fc, "2 Miles", "FULL", "ROUND", "ALL") print "Buffer Operation Complete." #Add the newly created Buffer Layer to your MXD print "Adding Buffer to Map Document" arcpy.mapping.AddLayer(df, out_fc, "AUTO_ARRANGE") print "Script Complete"
ログインすると、投稿したり、更新をフォローしたりできます。初めてですか?無料アカウントを登録しましょう。
