can you inform me about the version of cx_Oracle and Python that i should install that are compatible with the above mentioned softwares?
also what are the steps that i must execute to access Oracle from Python, and use cx_oracle with python ?? is it obligate to install ArcGIS if yes what is the version that I should install??thank you very much.
### Build a DSN (can be subsitited for a TNS name) dsn = cx_Oracle.makedsn("myconn", instance, schema) oradb = cx_Oracle.connect("User", "Password", dsn) cursor = oradb.cursor() _sqlQry = """SELECT table1.Field1, table1.Field2 FROM table1 WHERE table1.Field1 IN (""" + parameter1 + """)"""" cursor.execute(_sqlQry) datArray = [] cxRows = cursor.fetchall() for cxRow in cxRows: datArray.append(cxRow) #close the conn to ora cursor.close() oradb.close() del cxRows, cursor #I also incorporate the Pandas library for doing computations and table operations DF = DataFrame(datArray, columns=['field1', 'field2']) #convert pandas DataFrame result into a numpyarray dfar = DF.to_records() nmpyar = np.array(dfar, np.dtype([('field1', '|S25'), ('field2', '<f8')])) ##now covert the numpyarray to the gdb table in the default.gdb arcpy.da.NumPyArrayToTable(nmpyar, r"H:\Documents\ArcGIS\Default.gdb\numpytab")
ログインすると、投稿したり、更新をフォローしたりできます。初めてですか?無料アカウントを登録しましょう。
