Hi-
I am trying to reorder coded values in a domain in a geodatabase and I am currently getting ERROR 000535: Workspace does not exist when using the Sort Coded Value Domain tool. Any ideas how to get this to work?
Thanks!-Jessica
This helped, thanks!
Same issue with 10.2.1, disabled background and resolves
Believe it or not, this worked.
Disabling background geoprocessing also works for 10.5.1. Else it will not sort nor does it throw an error.
thanks
I am using ArcGIS Pro 2.9.5 and 3.1.0, and I have been getting this error message when trying to rename domains. I removed all spaces from the path names for the FileGDB that I am working in, and the error was resolved.
