Unable to load http://elevation3d.arcgis.com/arcgis/rest/services/WorldElevation3D/Terrain3D/ImageServer?f=json status: 0
I am not seeing any errors. It looks like the second link posted is just to the web scene viewer and not to the story map you are seeing an issue with. Can you post a link to the story map?
thanks
Rus
Web Scene Viewer
The problem is with ArcScene, you are correct.
The ArcScene was never set up, and will get removed since the person who would have worked on it moved on to a new job. The story maps are worth looking at, they are wonderful.
http://arcserver2.oconeesc.com/WebGIS/StoryMaps/index.html
