But I didn't think it was possible to use python with Arc 9.3.1....is it?
Mid([Row_Col],1,InStr([Row_Col],"-")-1)
I want to extract the columns and rows into their own fields such that "23-999" becomes "23" and "999" using "-" as a delimiter. The problem is that the lengths are variable, eg the field can contain values like "1-2", "351-7", "81-253" which makes substring, trim, left and right commands tricky.
!Col_Row!.split("-")[0] !Col_Row!.split("-")[1]
Try something like this in the field calculator.Expression:ReplaceLastNumber(!textfield!, !numberfield!) Code block:import re def ReplaceLastNumber(text_value, number_value): numbers = re.findall("\d+", text_value) if numbers: last_number = numbers[-1] last_number_index = text_value.rfind(last_number) return text_value[:last_number_index] + str(number_value) + text_value[last_number_index + len(last_number):] else: return text_value
