I would like to add codes to search so able to perform similar way when type on a text box.
rzufelt -I still try to work on the ideas you gave. I will give you a feedback later. I appreaciate your time.Bjorn - I try work on similar way header controller has on esearch widget or locate widget. Haven't got any success yet. Basically just like google search when you type in a text box, it will give you some char to choose. Robert has this on his search widget on his GIS site. I hope can give a starting point from here. Thanks all.
xmlns:managers="com.yahoo.astra.mx.managers.*" <fx:Declarations> <managers:AutoCompleteManager maxRowCount="9" id="autoCompleteMgr" dataProvider="{myXML.name}" target="{txtItem}" minCharsForCompletion="1" autoFillEnabled="true"/> </fx:Declarations> \\Based on the first digit of the address . . . it loads a different xml. if (clickedInTextInput == true && txtItem.text.length >= 4 && addrSearchVis == true) { txtItem.text = txtItem.text.toUpperCase(); if (int(txtItem.text.charAt(0)) >= 6 && int(txtItem.text.charAt(0)) >= 6) { XML_URL = "com/a" + txtItem.text.charAt(0) + ".xml"; } if (int(txtItem.text.charAt(0)) <= 5) { if (int(txtItem.text.charAt(1)) <= 9) { XML_URL = "com/a" + txtItem.text.charAt(0) + "8a" + txtItem.text.charAt(0) + "9.xml"; } if (int(txtItem.text.charAt(1)) <= 7) { XML_URL = "com/a" + txtItem.text.charAt(0) + "6a" + txtItem.text.charAt(0) + "7.xml"; } if (int(txtItem.text.charAt(1)) <= 5) { XML_URL = "com/a" + txtItem.text.charAt(0) + "4a" + txtItem.text.charAt(0) + "5.xml"; } if (int(txtItem.text.charAt(1)) <= 3) { XML_URL = "com/a" + txtItem.text.charAt(0) + "2a" + txtItem.text.charAt(0) + "3.xml"; } if (int(txtItem.text.charAt(1)) <= 1) { XML_URL = "com/a" + txtItem.text.charAt(0) + "0a" + txtItem.text.charAt(0) + "1.xml"; } } var myXMLURL:URLRequest = new URLRequest(XML_URL); var myLoader:URLLoader = new URLLoader(myXMLURL); myLoader.addEventListener("complete", xmlLoaded); } function xmlLoaded(evtObj:Event):void { myXML = new XML(); myXML = XML(myLoader.data); myLoader.removeEventListener("complete", xmlLoaded); autoCompleteMgr.openDropdownForTarget(txtItem); }
