import arcpy from arcpy import env from arcpy.sa import * env.workspace = r"C:\folder1" list = [] for raster in arcpy.ListRasters("*"): list.append(raster) for n in list: env.workspace = r"C:\folder2" if n in arcpy.ListRasters("*"): ras2 = n outPlus1 = Plus(n, ras2) env.workspace = r"C:\folder3" if n in arcpy.ListRasters("*"): ras3 = n env.workspace = r"C:\folder4" if n in arcpy.ListRasters("*"): ras4 = n outPlus2 = Plus(ras3, ras4) outPlus3 = Plus(outPlus1, outPlus2) outPlus3.save(r"C:\output" + "\\" + n)
I tried incorporating this script to add rasters but I keep getting errors. Here's the code I used:
import arcpy, os
import arcpy.sa
env.workspace = 'D:/Batch_Research_Test/Add_Rasters/DN'
env.overwriteOutput = True
raster_list = []
raster_list.append(raster)
for r in raster_list:
env.workspace = 'D:/Batch_Research_Test/Add_Rasters/Cloud'
if r in arcpy.ListRasters("*"):
cloud = r
outPlus1 = Plus(r, cloud)
env.workspace = 'D:/Batch_Research_Test/Add_Rasters/Shadow'
shadow = r
outPlus2 = Plus(outPlus1,shadow)
outPlus2.save(r"D:\Batch_Research_Test\Add_Rasters\Output" + "\\" + r)
Hi Angira,
What is the error you are receiving?
Hi Jake,
Thanks for your email. Here's what I get when I run the code:
"Traceback (most recent call last):
File
"C:\Python27\ArcGIS10.1\Lib\site-packages\Pythonwin\pywin\framework\scriptutils.py",
line 326, in RunScript
exec codeObject in __main__.__dict__
File "D:\Batch_Research_Test\Scripts\Test\Add_Rasters2.py", line 17, in
NameError: name 'Plus' is not defined"
Thanks!
Angira
Replace:
with:
I made that change and here's what I got:
NameError: name 'cloud' is not defined"
It doesn't look like any rasters are being found in your folder:
Try adding some print statements to further debug this code. Ex:
import arcpy, os from arcpy import env from arcpy.sa import * env.workspace = 'D:/Batch_Research_Test/Add_Rasters/DN' env.overwriteOutput = True raster_list = [] for raster in arcpy.ListRasters("*"): raster_list.append(raster) for r in raster_list: print r env.workspace = 'D:/Batch_Research_Test/Add_Rasters/Cloud' if r in arcpy.ListRasters("*"): print r cloud = r else: print 'raster not found' outPlus1 = Plus(r, cloud) env.workspace = 'D:/Batch_Research_Test/Add_Rasters/Shadow' if r in arcpy.ListRasters("*"): print r shadow = r else: print 'raster not found' outPlus2 = Plus(outPlus1,shadow) outPlus2.save(r"D:\Batch_Research_Test\Add_Rasters\Output" + "\\" + r)
