Hi Everybody. I am following this instruction Esri CityEngine Essentials 2: Build the Foundation
but for some reason i am not able to see the Texture how it suppose it does nor reflect the aerial it just a black image. I modify my tif file to 4000 by 4000 but https://www.dropbox.com/s/h7ho8t2uzl3v6hr/CALLES.shp.zip?dl=0
Here you can find my data, it seem correct, I can see it perfectly in ArcMap but when I try to see it as it suppouse in City Engine, I just see black.
Could you help me!
thanks
DLL
Hi Diego
For example, I have a TIN.tif and a "picture" of my TIN in jpg format.:
Hi Luiz
I followed your advice however still not working and having a black texture. I have exported to several formats such as JPG, PNG, TIFF, etc but nothing work.
Thanks for helping.
Claudia
Hello Claudia
Can you view the texture with an standard image viewer?
If this is possible, it also should work in CityEngine.
To further investigate this, I'd need your image data.
I have the same exact problem the image works in ArcMap and ArcScene but when I import it as a texture for my dtm it only shows up black. I REALLY NEED TO GET THIS WORKInG. Can anyone help me
