Hi there,Thank you very much for replying to my problem, much appreciated. I am using ArcGIS version 10.0. Is there a way of changing this environmental setting, as you proposed, in 10.0?Thanks
I'm using 10.5 sp 5 and I'm finding that Feature Class to Feature Class will not write descriptions. Instead it will add the domain table to the output GDB as to satisfy the domain link in the field. I created a blank PGDB, used FC to FC with a domain linked FC as the input and a new layer as the output in the blank PGDB. After successful completion I see domain tables in my output PGDB and a Select By Attributes in ArcMap reveals that the layer is in fact referencing domain codes.Can ESRI confirm this behavior in 10.0 SP5? As I understand the post above, the environment variable is not available in 10.0 but the functionality was expected to have been built into the FC to FC geoprocessing tool. Is that correct?
