Is it possible to change the background color of a widget in ArcGIS Online Assistant? I want to change the white area to grey. If not through AGOL Assistant, then how would I go about customizing this?
Thanks!
Scott,
No this can not be done using AGOL assistant. You would have to deploy an app using WAB Developer to your own web server to be able to make this change.
ログインすると、投稿したり、更新をフォローしたりできます。初めてですか?無料アカウントを登録しましょう。
