I created a story map using the countdown template and I was wondering if there is a way to make the overview map zoom level to be closer? Currently, it looks like this:
But I would like the default zoom level to look like this:
I adjusted the Initial overview map zoom level for wider map aspect ratio, and this adjusted the problem. Unfortunately, it adjusts the overview map and the close up map, so this will not work for what I want. Thanks, though.
In the config.js file, there is a setting for initial zoom level:
//Initial zoom level for overview map initialZoomLevel: 2,
I tried different numbers but it didn't have an effect on the zoom level for the map.
I downloaded the template and tried it on my end... It works well:
Change "initialZoomLevel""
Re-load map:
