Hello.
i need to add a watermark (png or jpg file) whenever the user prints the map. Currently we are using PrintTask.
thanks
Are you using your own custom print service?
nope. but i could develop one
That is how I was able to add a watermark. I created a custom print service that uses template files (mxds), which is where you save the watermark file to.
Here is the help I used to set this up in the 10.2 environment
ArcGIS Help (10.2, 10.2.1, and 10.2.2)
I hope this helps.
gonna check it. thanks.
ログインすると、投稿したり、更新をフォローしたりできます。初めてですか?無料アカウントを登録しましょう。
