Hello,I have a BA10.1 premium installed with 2011/2016 dataI am trying to run the market penetration tool with the SF-customers data shipped with tutorial data.The inputs are : Which Layer contains your customer: sf_custs (from tutorial data)Select base Layer: Block GroupsWhere are the total market counts for each area? : 2011 Total Population 30-34 (BA data)The tool attempts to initialize the process and abruptly stops and gives me this message"There are no analysis areas in this extent".Change in the extent of the map makes no change.If I input same variables in BA 10 with 2011/2016 data the tool runs fine and gives me a Market Penetration layer.Any suggesstions/ help is appreciated!
