Do u need a different views for Folders & Files in Document Library???????
I did lot of finding for your query and got this. Try it, it may be useful for you.....msdn.microsoft.com/en-us/library/ee231579.aspx
Hello,I am facing the same problem and I can reproduce this behavior.Can someone from ESRI clarify if this is a known bug?Thank you!Carsten
Hello All,Yes, I can confirm that this is a bug with the ArcGIS SharePoint Map Web Part. Items in folders should work, as you've pointed out. I'll add this to our internal bug queue.Thanks,Katy
サインインすると、投稿したり、更新をフォローしたりできます。初めての方ですか?無料アカウントを登録しましょう。
