Matt,
Here is a quick example of working with the deferred:
curentLayer<SPAN class="punctuation token">.</SPAN><SPAN class="token function">selectFeatures</SPAN><SPAN class="punctuation token">(</SPAN>query<SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>result<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN> <SPAN class="comment token">//todo work with the selection result</SPAN> <SPAN class="comment token">//now that the selection is complete</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
It looks like you need to wait for the selection method to complete before you try and access the selected feature. The select features method returns a deferred so you need to wait for the deferred to resolve.
thanks for the tip Robert, I'm trying timeouts and promises to see if this fixes it, I'll share the results when I have them
