<!doctype html> <html lang="en"> <head> <meta charset="utf-8"> <meta http-equiv="X-UA-Compatible" content="IE=7,IE=9" /> <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/> <title></title> <link rel="stylesheet" href="http://serverapi.arcgisonline.com/jsapi/arcgis/2.5/js/dojo/dijit/themes/tundra/tundra.css"> <link rel="stylesheet" href="http://serverapi.arcgisonline.com/jsapi/arcgis/2.5/js/esri/dijit/css/Popup.css"> <style> html, body { height: 100%; width: 100%; margin: 0; padding: 0; } #map{ margin: 0; padding: 0; } </style> <script>var dojoConfig = { parseOnLoad: true };</script> <script src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=2.5"></script> <script> dojo.require("dijit.layout.BorderContainer"); dojo.require("dijit.layout.ContentPane"); dojo.require("esri.map"); dojo.require("esri.layers.MapImageLayer"); var map; function init() { var initExtent = new esri.geometry.Extent({"xmin":-9005991,"ymin":3866418,"xmax":-8620442,"ymax":4022043,"spatialReference":{"wkid":102100}}); map = new esri.Map("map",{extent:initExtent}); var basemap = new esri.layers.ArcGISTiledMapServiceLayer("http://server.arcgisonline.com/ArcGIS/rest/services/World_Topo_Map/MapServer"); map.addLayer(basemap); // create and add the layer var mil = new esri.layers.MapImageLayer({ 'id': 'usgs_screen_overlay' }); map.addLayer(mil); // create an add the actual image var mi = new esri.layers.MapImage({ 'extent': { 'xmin': -8864908, 'ymin': 3885443, 'xmax': -8762763, 'ymax': 3976997, 'spatialReference': { 'wkid': 3857 }}, 'href': 'http://hdds.usgs.gov/hdds2/view/overlay_file/AM01N33_269827W079_1773002011082800000000MS00' }); mil.addImage(mi); dojo.connect(map, 'onLoad', function() { dojo.connect(dijit.byId('map'), 'resize', map, map.resize); }); } dojo.ready(init); </script> </head> <body class="tundra"> <div data-dojo-type="dijit.layout.BorderContainer" data-dojo-props="design:'headline',gutters:false" style="width: 100%; height: 100%; margin: 0;"> <div id="map" data-dojo-type="dijit.layout.ContentPane" data-dojo-props="region:'center'"> </div> </div> </body> </html>
ログインすると、投稿したり、更新をフォローしたりできます。初めてですか?無料アカウントを登録しましょう。
