When I use save snaphot it only exports the lower left part of the viewport (see attached pics). I am working on a Mac with OSX 10.9.5 with Retina display and the issue appears with both CityEngine versions 2013.1 and 2014.1. However I didn't have this issue with my older Mac with a slightly older OSX and without Retina display. Any idea why this happens and how I could solve it?
Hi Bruno,
I heard from Roman you're talking about screenshots in python.. or is it the same via the UI ?
Just to make sure ..
Matthias Buehler
Head of 3D Technologies
twitter: @MattB3D
Garsdale Design Limited matthias.buehler@garsdaledesign.co.uk
www.garsdaledesign.co.uk
Hi Matt
Small World :-). We have exactly the same issue in the UI and in python...
I tried here and it seems to work fine .. both via UI and python ..
strange.. does this happen in each and every snapshot you take ?
m.
Hmm.. Yes, it happens with every snapshot. It's definitely related to the mac retina display. I found a workaround on the apple website in the meantime. You need to open cityengine in low-resolution mode when you want to export snapshots and then it works fine:
So I guess this means that you can't work in the high-resolution mode when you want to export snapshots. Fortunately the rest of the functionalities in CityEngine seem to work fine in both modes.
Thanks for your help!
