I am looking for a way to select points more easily.
I do not care if I accidently select more than one.
does anyone have a solution to this.
my field staff assume that collector isn't working if they touch a feature and it doesn't get selected.
This is a large issue we face as well. Additionally we must use screen protectors that further reduce sensitivity.
My recommend to ESRI would be the ability to draw a box and anything in the box would be selected.
Please solve this frustrating issue ESRI!
This is a problem for my organization too. I have noticed that if you use a Feature Server instead of a Map Server version of the point service that the selection process works very well. The big problem with this is that the point's display scale is off/very small for Feature Server services.
