私の組織には2つのグループがあります。私は管理者です。アイテムを一方のグループからもう一方のグループに移動することは可能ですか?<\/P>
<\/P>
最終的な目標は、新しいUsernameが必要なため、どちらかのグループを削除することです。Usernameは変更できないと読みました。一度作成されるとそのまま残ります。 <\/P>
これをどのように行うか教えていただけますか?<\/P><\/BODY><\/HTML>
You could uncheck sharing the items with the "old" group, and check for sharing item with the new group.
Share items—ArcGIS Online Help | ArcGIS
You can change your First Name and Last Name without changing the UserName.
Else, if there is room to create another user account, you could create one with the desired username, grant it Administrator privileges, and move the items created by the administrator. Then, you could delete the older User Account.
Tim, usually individual items have an owner, they are not owned by a group. As Jayanta mentioned, you could just unshare/share with the groups you want within an organization.
Are you trying to change ownership of move between folders?
I've started to play with the Jupyter Notebook and the Python API, and it has (or is getting) options for making much of this easier.
Thank you. This is partially helpful. But, how do I move/copy items from one group to another in the same organization?
