My data is structured with counties as rows and individual species as columns with the presence/absence indicated by a 1 or 0. So in order to run the code for all species I am trying to select the values > 0 within the column of a species, export a jpeg with those counties selected, clear the selection, and then move to the next column (species) until it runs for all species.
where = '\"%s\" > 0' % X
I started with a simple polygon shapefile of counties and then merged the attribute table with a spreadsheet of all species of interest formatted like stated above. Would it be better to have the species as rows and counties as columns or in a single column with them comma-delimited per species? If so is there an easy way to do this?
tv = arcpy.MakeTableView(SpecCounty,"tv") arcpy.SelectLayerByAttribute(tv,"","SPECIES = \'%s\'" % X) # KEEP_COMMON will unselect non-matching rows arcpy.AddJoin("County_poly","COUNTY",tv,"COUNTY","KEEP_COMMON") # # .. make your plot here .. # # Now remove the join (this clears the selection for the next loop) joinName = gp.Describe("County_poly").Name arcpy.RemoveJoin("County_poly",joinName)
# where "SpecField" LIKE '%Achillea millefolium%') where = '\"%s\" LIKE \'%%%s%%\' % (SpecField,X)
#Import arcpy and set workspace import arcpy import arcpy.mapping arcpy.env.workspace = r"P:\CoWetlandTools\maps\distribution_maps_Johns_pytest" import arcpy.sa specieslist = ['Achillea millefolium', 'Acroptilon repens', 'Actinea osterhoutii', 'Adenocaulon bicolor', 'Adoxa moschatellina', 'Ageratina herbacea', 'Agoseris �?agrestis', 'Agoseris �?montana', 'Agoseris agrestis', 'Agoseris attenuata', 'Agoseris aurantiaca', 'Agoseris frondifera', 'Agoseris glauca'] for X in specieslist: #select counties each species is known to occur #Create Loop and List to run processing for arcpy.SelectLayerByAttribute_management ("counties_edited_datamergetest", "NEW_SELECTION", "'Achillea millefolium' in ('"+'\',\''.join(specieslist)+"') > '0'") #Export selected to jpeg mxd = arcpy.mapping.MapDocument(r"CURRENT") arcpy.mapping.ExportToJPEG(mxd, r"P:\CoWetlandTools\maps\"'Achillea millefolium' in ('"+'\',\''.join(specieslist) + "').jpg") #clear selected attributes arcpy.SelectLayerByAttribute_management ("counties_edited_datamergetest", "CLEAR_SELECTION") #finished print "Finished"
arcpy.env.workspace = r"P:\CoWetlandTools\maps\distribution_maps_Johns_pytest" #"r" at beginning of path string
where = "X in ('" + '\',\''.join(specieslist) + "')"
#Import arcpy and set workspace import arcpy import arcpy.mapping arcpy.env.workspace = "P:\CoWetlandTools\maps\distribution_maps_Johns_pytest" import arcpy.sa specieslist = ['Achillea millefolium', 'Acroptilon repens', 'Actinea osterhoutii', 'Adenocaulon bicolor', 'Adoxa moschatellina', 'Ageratina herbacea', 'Agoseris �?agrestis', 'Agoseris �?montana', 'Agoseris agrestis', 'Agoseris attenuata', 'Agoseris aurantiaca', 'Agoseris frondifera', 'Agoseris glauca'] for X in specieslist: #select counties each species is known to occur #Create Loop and List to run processing for arcpy.SelectLayerByAttribute_management ("counties_edited_datamergetest", "NEW_SELECTION", "X in "str(specieslist)" > 0") #Export selected to jpeg mxd = arcpy.mapping.MapDocument(r"CURRENT") arcpy.mapping.ExportToJPEG(mxd, r"P:\CoWetlandTools\maps\"X in str(specieslist)".jpg") #clear selected attributes arcpy.SelectLayerByAttribute_management ("counties_edited_datamergetest", "CLEAR_SELECTION") #finished print "Finished"
