See these help pages:http://help.arcgis.com/en/arcgisonline/help/index.html#/Using_a_single_symbol/010q0000008q000000/http://help.arcgis.com/en/arcgisonline/help/index.html#/Saving_item_properties/010q0000009n000000/
Veronica,Sure you can change the symbology in the portal web map and re-publish. The other way would involve changing code in the Flex Viewer source.
Veronica, As your data is public I used your data and got the popup to work with what I sent you. You need to double check your sets and see if you missed something.
Veronica,Another option is to use the web map as authored on arcgis.com. To do this, you would just set the map tag like this:<map itemid="c4670a647b2f42e3b6818edc7cb485cd"></map>
Veronica, You have to setup your own popup configuratione file. Here is what you will need:Create a PopUp_Voting.xml file in the popups folder in your Flex Viewer<?xml version="1.0" ?> <configuration> <title>{VOTING_LOC}</title> <fields> <field name="PRECINCT" alias="Precinct" visible="true"/> <field name="VOTING_LOC" /> <field name="ADDRESS" alias="Address" visible="true"/> </fields> <showattachments>false</showattachments> </configuration> <!-- Pop-up configuration file for: http://services.arcgis.com/4B9WU9185SohZnyi/ArcGIS/rest/services/City_voting_locations/FeatureServer/0 See pop-up documentation at http://links.esri.com/flexviewer/popups -->and add the popoupconfig attribute to the main config.xml like this:<layer label="City_voting_locations" type="feature" visible="true" alpha="1" popupconfig="popups/PopUp_Voting.xml" url="http://services.arcgis.com/4B9WU9185SohZnyi/ArcGIS/rest/services/City_voting_locations/FeatureServer/0"/>
Veronica, Not sure why you are using 2.3 when you could be using 3.0 but anyway... Here is what you need to add to the main config.xml <operationallayers> <layer label="City_voting_locations" type="feature" visible="true" alpha="1" mode="onDemand" url="http://services.arcgis.com/4B9WU9185SohZnyi/arcgis/rest/services/City_voting_locations/FeatureServer/0"/> </operationallayers>Don't forget to click the top arrow (promote).Follow the steps as shown in the below graphic:
Veronica, Are you talking about using Application builder or the Flex Viewer uncompiled in Flash Builder or something else?
