約1500のxyzファイル(対応するlasファイルもあります)をDEMに変換したいと考えています。以下のワークフローをテストしましたが、期待通りに動作しているようです。<\/P>
<\/P>
How To: Convert points in XYZ file format to raster<\/A> <\/P><\/P>私のxyzファイルのポイント間隔はすべて3フィートです。したがって、スクリプトを使うかツールのバッチモードで1500ファイルを処理できると思っています。ラスタ補間部分のワークフローについてベストプラクティスがあるかどうか気になっています。テストではデフォルト設定でIDWを使用しました。<\/P><\/P>ありがとうございます!<\/P><\/BODY><\/HTML>
Forest
As with so many questions, the simple (but not helpful) answer is "it depends".
To be more helpful, I'll expand on some of the considerations - but as Dan indicated, you should test IDW vs. NaturalNeighbor on a small sample to see which will work best for you. In general IDW will leave you with a rougher DEM (although possibly more accurate), whereas NatNeighbor will be smoother - but there are other considerations:
The above should guide you to pick a good area to test - I'd suggest finding an area with some larger "NoData" gaps (if you have any) especially at tile boundaries, and process either 4 tiles in 2x2 arrangement or perhaps more, and look at a hillshade of the resulting outputs to see if there are edge effects. If any of your tiles have NoData at the edges (and you do fill the NoData voids), I'm sure you'll find discontinuities if you process these files separately to create DEMs.
If you have not invested a lot of effort thus far in the files, and/or if a small test does not work out well, I'd encourage you to look at our recommended workflow for generating DEMs from Lidar in the Image Management Guidebook (look for the Aerial Lidar section here: Image Management ). This would presume you have good ground classification for your points in the LAS files, but I'm suggesting you may not want to use the XYZ point files and just use our workflow to go from LAS to tiled DEMs in Tiff format. This would process all of your data as one logical project (or several large projects, if it's really not contiguous data) to avoid edge artifacts, and the downloadable tool referenced in this workflow (LAS Dataset to Tiled Rasters) gives you a lot of flexibility for creating DEM tiles including file names, boundaries, and metadata to go with the tiles.
re: my question #4 above, an option that some organizations use is NOT to fill the NoData voids (or "not if greater than xyz pixels"), and then when the DEM tiles are used (presuming users have either ArcGIS Desktop/Pro or a web client built with our APIs), if you manage them with a Mosaic Dataset and add the "Elevation Void Fill" function, you can have a watertight DEM but allow the user to control the parameters of the void filling that best suit their application, and also explicitly see where the voids are so they know which values are being interpolated. I wouldn't suggest this if you have public users, but if you are serving technical staff in your organization, they may prefer to see the data voids before proceeding.
I hope that is helpful. Cody B.
There is no perfect interpolator, pick one if you don't like the results then you can see if others work better given the nature of your data.
To comment on Cody's statement about 'it depends' not being useful.
Perhaps the shear number of interpolators and their location in the toolsets is a first clue that this is a field of venture where 'is depends' should guide one to examine what each interpolator works best at and what each one does.
3D analyst An overview of the Raster Interpolation toolset—Help | ArcGIS for Desktop
Geostats analyst An overview of the Interpolation toolset—Help | ArcGIS for Desktop
Spatial analyst An overview of the Interpolation toolset—Help | ArcGIS for Desktop
There are some duplication, but some unique to the toolset.
Then there is the question of your data... once you understand the interpolators, then you can view them in light of your data.
Thanks for the feedback Cody.
1) The xyz data looks tight. There are no gaps and the points are at 3 foot spacing across all of the files I have looked at.
2) This is a vendor provided dataset. They have given us bare earth as well as what they call "Full Feature" (I am not sure if that is an industry standard term but it is the surface reflection). But, all I care about is the bare earth. I don't have a lot of time into the processing so far. Mostly, just research to understand the correct path forward. I would guess that the vendor has insured that the edges of the xyz "tiles" mesh up nicely. Artifacts on the seams would be bad.
3) Processing time is not a big deal. I would like to be done in a few days. Based on my work so far I think this is realistic.
4) The data will be used in ArcGIS desktop and other geospatial applications such as Petrosys. In the end it is a little hard to predict all of the ways that it will be used. My plan is to make tiffs off of it and then create a mosaic dataset. People can use the tiffs if their application can not consume the mosaic. Thank you for the void fill tip.
If this workflow does not pan out I will try your alternate workflow.
