I'm not sure if the Zonal Stats works on linear features (polylines).
If it does, not sure why the error.
If it won't, you may be able to:
It seems this would get you the minimum values where the lines are.
Mark
I know this post is old but I'm running into a similar issue. I'm trying to run Zonal Stats onto a dem to get minimum value from overlaying linear features. However, the tool won't work. It keeps giving me not valid input error (error 000861).
@EricRice mentioned above it should work though so is there some special prep I need to do for 32 bits float raster before I run the zonal stats tool?
Thanks!
