I have done this, although it is not technically part of the toolbar, it looks like it.Added the widget to the UI elements (along with the full screen widget) so it is there when it opens and works with one click.code:<widget right="150" top="5" config="widgets/FullScreenWidget/FullScreenWidget.xml" url="widgets/FullScreenWidget/FullScreenWidget.swf"/><widget right="109" top="5" config="widgets/ExportMap/exportMap.xml" url="widgets/ExportMap/exportMap.swf"/>see attached image.
<!-- UI elements -->
Jeff, Updated version 2.2 is now in the code gallery.
Another great widget from Robert which is much appreciated.I would like to fire off the widget from the toolbar instead of the current lower left position.I edited the config.xml to place the widget in the toolbar but as expected, when you click on it the widget appears in the lower left and you have to click on it again to run it.What code changes would be needed to just fire it from the toolbar?Thanks again Robert.Nestor.
contain an interface, such as map title, map layout options and include map attribute layers
<?xml version="1.0" ?> <configuration> <title>ArcGIS Viewer for Flex</title> <logo>assets/images/logo.png</logo> <style> <colors>0xffffff,0x333333,0x101010,0x0,0xffd700</colors> <alpha>0.8</alpha> </style> <!-- replace the following url with your own geometryservice --> <geometryservice url="http://tasks.arcgisonline.com/ArcGIS/rest/services/Geometry/GeometryServer" useproxy="false"/> <widgetcontainer layout="float"> <widget icon="assets/images/i_target.png" label="Find an address" config="widgets/Locate/LocateWidget.xml" url="widgets/Locate/LocateWidget.swf"/> <widget icon="assets/images/i_draw2.png" label="Draw and Measure" config="widgets/Draw/DrawWidget.xml" url="widgets/Draw/DrawWidget.swf"/> <widget icon="assets/images/i_print.png" label="Print" config="widgets/Print/PrintWidget.xml" url="widgets/Print/PrintWidget.swf"/> </widgetcontainer> <widget url="widgets/Navigation/NavigationWidget.swf" config="widgets/Navigation/NavigationWidget.xml" left="10" top="50"/> <widget url="widgets/OverviewMap/OverviewMapWidget.swf" config="widgets/OverviewMap/OverviewMapWidget.xml" right="-2" bottom="-2"/> <widget url="widgets/MapSwitcher/MapSwitcherWidget.swf" config="widgets/MapSwitcher/MapSwitcherWidget.xml" right="20" top="55"/> <widget url="widgets/HeaderController/HeaderControllerWidget.swf" config="widgets/HeaderController/HeaderControllerWidget.xml" left="0" top="0"/> <widget url="widgets/ExportMap/exportMap.swf" config="widgets/ExportMap/exportMap.xml" left="3" bottom="45"/> <map esrilogovisible="true" openhandcursorvisible="true" scalebarvisible="true" zoomslidervisible="false" wraparound180="true" addarcgisbasemaps="true" top="40"/> </configuration>
ログインすると、投稿したり、更新をフォローしたりできます。初めてですか?無料アカウントを登録しましょう。
