Can anyone tell me is it possible to make a connection to a Access DateBase in ArcMap. If not, is possible to pull the Tables for the Access Database into a GeoDataBase.
So if I understand this correctly, you are displaying updateable layers in real time from an access database hosted by arcGIS? If so, can I update that database from a mobile client? So I would be adding social events to an Access "calendar" for display on a map...or is this offbase for this product?
Thanks!
サインインすると、投稿したり、更新をフォローしたりできます。初めての方ですか?無料アカウントを登録しましょう。
