Since javascript API vV4.* there is a blue outline around the map, when we interact with the view.
You can see this on the sample app https://developers.arcgis.com/javascript/latest/sample-code/intro-mapview/index.html Just move the map and you'll notice that blue outline around the view.
Do you know how to remove or disable that feature ?
thank you all
Focus rectangles are an important part of accessibility. But if you really want to remove it anyway.
<SPAN class="selector token">.esri-view .esri-view-surface--inset-outline:focus::after</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="property token">outline</SPAN><SPAN class="punctuation token">:</SPAN> none <SPAN class="important token">!important</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
thank you, it worked
Indeed it stopped working due to change of DOM inside view from version 4.26 to 4.27. Updated CSS adjusted by this change:
.esri-view .esri-view-surface--touch-none:focus::after { outline: none !important; }
does not seem to work anymore in 5.x, any new idea?
Adjusted for version 5.0.
.esri-view .esri-view-surface:focus::after, .esri-view .esri-view-surface:focus-visible::after { outline: none !important; }
Just a small accessibility note: while removing the focus outline may look better visually, it can make keyboard navigation less accessible. Keeping some subtle visible focus indicator is usually a better approach.
.esri-view .esri-view-surface:focus::after, .esri-view .esri-view-surface:focus-visible::after { outline: 2px solid rgba(255, 255, 255, 0.75); outline-offset: -4px; }
If / when you migrate to use the arcgis-map component, we added a css variable to change the focus color. If you are not concerned about accessibility you could set it to be transparent
arcgis-map { --arcgis-view-color-focus: transparent; }
Hi, thanks.That does work.Accessability is a thing, yes, but the permanent toggling of the Map-Frame, when doing different interactions with tools, was irritating pretty much.
ログインすると、投稿したり、更新をフォローしたりできます。初めてですか?無料アカウントを登録しましょう。
