<layers onlythese="false" />
<layers onlythese="false"> <layer> <name>3/27/13 - reduced vegetation supression - AA11</name> <id>2</id> <url>https://www.sciencebase.gov/arcgis/rest/services/usminmap/Landsat7_West/MapServer</url> <fields> <field name="Red" alias="Red"/> <field name="Green" alias="Green"/> <field name="Blue" alias="Blue"/> <field name="Contrast" alias="Contrast"/> <field name="Materialid" alias="Material Id"/> <field name="Count" alias="Count"/> <field name="Opacity" alias="Opacity"/> <field name="Pixel Value" alias="Pixel Value"/> <field name="OID" alias="Object Id"/> </fields> <links/> <zoomscale>2000</zoomscale> <forcescale>true</forcescale> </layer> </layers>
I added the layer configuration you suggested to my xml, but still the layer names will not display, so that does not appear to be a resolution to my issue*.
My web app contains about 60+ such rasters, so I sincerely hope that I don't have to manually enter all that information into the xml for each of them.
On a private Flex app on my test server, the Identify widget version is listed as 3.5.1 when I use the ALT method, even though version 3.6.2 is installed
Here is a shot of ArcMap 10.2 into which I loaded the Landsat7_West map service from the 10.2 Server. The ArcMap Identify tool results do show the layer name as expected:http://cmerwebmap.cr.usgs.gov/images/untitled.jpg
<id>2</id>
I am still confused as to why ArcMap Identify can read the layer name from the published service
<layer> <useproxy>true</useproxy> <name>3/27/13 - reduced vegetation supression - AA11</name> <id>2</id> <url>https://someserver/arcgis/rest/services/someservice/MapServer</url> <fields> <field name="Red" alias="Red"/> <field name="Green" alias="Green"/> <field name="Blue" alias="Blue"/> <field name="Contrast" alias="Contrast"/> <field name="Materialid" alias="Material Id"/> <field name="Count" alias="Count"/> <field name="Opacity" alias="Opacity"/> <field name="Pixel Value" alias="Pixel Value"/> <field name="OID" alias="Object Id"/> </fields> <links/> <zoomscale>2000</zoomscale> <forcescale>true</forcescale> </layer>
<layers onlythese="false"> <layer> <name>Landsat 7 - Northwestern U.S. - 3/27/13 - reduced vegetation suppression - AA11</name> <id>2</id> <url>http://cmerwebmap.cr.usgs.gov/ArcGIS/rest/services/Landsat7_West/MapServer</url> <fields> <field name="MaterialID" alias="Material ID"/> <field name="Value" alias="Pixel Value"/> </fields> <links/> <zoomscale>2000</zoomscale> <forcescale>true</forcescale> </layer>
<layers onlythese="false"> <layer> <name>Landsat 7 - Northwestern U.S. - 3/27/13 - reduced vegetation suppression - AA11</name> <id>2</id> <url>http://servername_10.2.1/ArcGIS/rest/services/Landsat7_West/MapServer</url> <fields> <field name="MaterialID" alias="Material ID"/> <field name="Pixel Value" alias="Pixel Value"/> </fields> <links/> <zoomscale>2000</zoomscale> <forcescale>true</forcescale> </layer>
<layer> <name>3/27/13 - reduced vegetation suppression - AA11</name> <fields> <field name="MaterialID" alias="Material ID"/> <field name="Pixel value" alias="Value"/> </fields> <links/> <zoomscale>2000</zoomscale> <forcescale>true</forcescale> </layer>
