Thanks everybody for the answersIsn't there any other option than recreating the tables in Oracle and then deleting them in Desktop? There are quite a lot of them, including in schemas that no longer exist and this would require quite some manual work. There is no complex relationship though.I would have hoped that there is some kind of metadata table that can simply be purged?
This is quite annoying cause I even have the opposite case now: a table that exists in Oracle (even has a shape column) but that is no longer displayed in ArcGIS... The problem probably arose while I had to delete and re-create this table a few times (sometimes within Oracle, sometimes within ArcGIS). If I rename this table, it appears in ArcGIS. But as soon as I give it its real name back, it disappears... My assumption is that there must be a record in the ArcSDE schema saying that this table is invalid or something...Any idea?
