My name is Erika, i would like to get help. I want to find the way in ArcPro how to find the near places depending on an address in a area (city).
Erika Solli
Have you looked at this tool:
Near—Help | Documentation
Can you provide an example of what you'd like to find near an address? Are you trying to something similar to Yelp or similar mobile apps that finds the nearest restaurant to your location?
Hi Robert thanks for you answer.
Okay so if I'm following you correctly, you want to do the following:
The other program is Non-Esri., is or own.
2. Is correct in the visualization of the map in own program i would to get the coordinates. Some times if it is a farm, the is only postcodes.
Hei,
2. The other program is our program, and inthis program i would like to get visualization
I guess the next question is can your non-Esri program read Esri data formats? Or what data formats does it read?
i, oru program is using xmlns men we get information for ArcGis with API and this is for get distanse (soulve route) betwen en pacient and one hospital for exempel. But we would like to in our program we can se the route and the closest hospitals, then we can know and the pasient travel to the closest one. I hope you understand me 🙂
For the ArcGIS API, are you using the File Geodatabase API or another? And the non-Esri application you referred to, is it XMINS MEN? Or am I'm not interpreting that correctly? Please advise.
