class ButtonClass1(object): """Implementation for UndoRedo_addin.button (Button)""" def __init__(self): self.enabled = True self.checked = False def onClick(self): edit = arcpy.da.Editor(r'C:\addin\projects\EditSession\f.gdb') edit.startEditing() edit.startOperation() arcpy.DeleteFeatures_management("fishparcels_line") arcpy.RefreshActiveView() edit.stopOperation() edit.stopEditing(True) arcpy.RefreshActiveView()
Thanks for the reply. Sorry I didn't notice it sooner.My question was more about getting a Python add-in to integrate with ArcMap's undo/redo stack like VBA. Your example works, but does not address 2 things I'm interested in:1) Accessing the workspace ArcMap is currently editing2) Setting a name for the operation, so ArcMap's undo button can say what would be undone.It does not look like Python add-in's can do this.Thanks,Mark
No need to mess around with ArcObjects and .NET. You can create your own edit stack. You can simply set a global variable that tracks the edits and is then accessible to other buttons.
For example, depending on the complexity of the edits performed by your add-in, you could have a global list to which you append information about the edits.
Here's an example of a simple edit button (it just buffers the selected features) with undo and redo buttons. Note that these are not the built-in undo/redo buttons, but Add-In buttons that you create. The edits here will be in a separate stack from the built-in edits.
<SPAN class="keyword token">import</SPAN> arcpy <SPAN class="keyword token">import</SPAN> pythonaddins MXD <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>mapping<SPAN class="punctuation token">.</SPAN>MapDocument<SPAN class="punctuation token">(</SPAN><SPAN class="string token">'CURRENT'</SPAN><SPAN class="punctuation token">)</SPAN> FN_SHAPE <SPAN class="operator token">=</SPAN> <SPAN class="string token">'SHAPE@'</SPAN> <SPAN class="comment token"># Global variables that will store the edit histories forward and backward</SPAN> undo_stack <SPAN class="operator token">=</SPAN> list<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> redo_stack <SPAN class="operator token">=</SPAN> list<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">class</SPAN> <SPAN class="token class-name">MakeEdits</SPAN><SPAN class="punctuation token">(</SPAN>object<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">def</SPAN> <SPAN class="token function">__init__</SPAN><SPAN class="punctuation token">(</SPAN>self<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN> self<SPAN class="punctuation token">.</SPAN>enabled <SPAN class="operator token">=</SPAN> <SPAN class="token boolean">True</SPAN> self<SPAN class="punctuation token">.</SPAN>checked <SPAN class="operator token">=</SPAN> <SPAN class="token boolean">False</SPAN> <SPAN class="keyword token">def</SPAN> <SPAN class="token function">onClick</SPAN><SPAN class="punctuation token">(</SPAN>self<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="comment token"># Get the selected layer in the table of contents</SPAN> lyr <SPAN class="operator token">=</SPAN> pythonaddins<SPAN class="punctuation token">.</SPAN>GetSelectedTOCLayerOrDataFrame<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="comment token"># Get a count of selected features in the selected layer</SPAN> fid_set <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>Describe<SPAN class="punctuation token">(</SPAN>lyr<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN>FIDSet <SPAN class="keyword token">if</SPAN> fid_set <SPAN class="operator token">==</SPAN> <SPAN class="string token">''</SPAN><SPAN class="punctuation token">:</SPAN> count <SPAN class="operator token">=</SPAN> <SPAN class="number token">0</SPAN> <SPAN class="keyword token">else</SPAN><SPAN class="punctuation token">:</SPAN> count <SPAN class="operator token">=</SPAN> len<SPAN class="punctuation token">(</SPAN>fid_set<SPAN class="punctuation token">.</SPAN>split<SPAN class="punctuation token">(</SPAN><SPAN class="string token">';'</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="comment token"># If at least one feature is selected</SPAN> <SPAN class="keyword token">if</SPAN> count <SPAN class="operator token">></SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="comment token"># Enable global modification of the undo_stack</SPAN> <SPAN class="keyword token">global</SPAN> undo_stack <SPAN class="comment token"># Get the name of the layer's OID field</SPAN> fn_oid <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>Describe<SPAN class="punctuation token">(</SPAN>lyr<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN>OIDFieldName <SPAN class="keyword token">with</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>da<SPAN class="punctuation token">.</SPAN>UpdateCursor<SPAN class="punctuation token">(</SPAN>lyr<SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">[</SPAN>fn_oid<SPAN class="punctuation token">,</SPAN> FN_SHAPE<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">as</SPAN> cur<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">for</SPAN> row <SPAN class="keyword token">in</SPAN> cur<SPAN class="punctuation token">:</SPAN> <SPAN class="comment token"># Add the relevant details to the editing stack</SPAN> undo_stack<SPAN class="punctuation token">.</SPAN>append<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">(</SPAN>lyr<SPAN class="punctuation token">,</SPAN> fn_oid<SPAN class="punctuation token">,</SPAN> row<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> row<SPAN class="punctuation token">[</SPAN><SPAN class="number token">1</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="comment token"># An arbitrary example edit</SPAN> row<SPAN class="punctuation token">[</SPAN><SPAN class="number token">1</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="operator token">=</SPAN> row<SPAN class="punctuation token">[</SPAN><SPAN class="number token">1</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">.</SPAN>buffer<SPAN class="punctuation token">(</SPAN><SPAN class="number token">500</SPAN><SPAN class="punctuation token">)</SPAN> cur<SPAN class="punctuation token">.</SPAN>updateRow<SPAN class="punctuation token">(</SPAN>row<SPAN class="punctuation token">)</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>RefreshActiveView<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">class</SPAN> <SPAN class="token class-name">RedoEdits</SPAN><SPAN class="punctuation token">(</SPAN>object<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">def</SPAN> <SPAN class="token function">__init__</SPAN><SPAN class="punctuation token">(</SPAN>self<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN> self<SPAN class="punctuation token">.</SPAN>enabled <SPAN class="operator token">=</SPAN> <SPAN class="token boolean">True</SPAN> self<SPAN class="punctuation token">.</SPAN>checked <SPAN class="operator token">=</SPAN> <SPAN class="token boolean">False</SPAN> <SPAN class="keyword token">def</SPAN> <SPAN class="token function">onClick</SPAN><SPAN class="punctuation token">(</SPAN>self<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">global</SPAN> undo_stack <SPAN class="keyword token">global</SPAN> redo_stack <SPAN class="keyword token">if</SPAN> len<SPAN class="punctuation token">(</SPAN>redo_stack<SPAN class="punctuation token">)</SPAN> <SPAN class="operator token">></SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="comment token"># Get the last item in the edit stack</SPAN> edit <SPAN class="operator token">=</SPAN> redo_stack<SPAN class="punctuation token">.</SPAN>pop<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="comment token"># Clear any existing selection on the layer, or else the cursor may</SPAN> <SPAN class="comment token"># not hit the necessary feature</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>SelectLayerByAttribute_management<SPAN class="punctuation token">(</SPAN>edit<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'CLEAR_SELECTION'</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="comment token"># A where clause to select the most recently edited feature</SPAN> wc <SPAN class="operator token">=</SPAN> <SPAN class="string token">'{} = {}'</SPAN><SPAN class="punctuation token">.</SPAN>format<SPAN class="punctuation token">(</SPAN>edit<SPAN class="punctuation token">[</SPAN><SPAN class="number token">1</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> edit<SPAN class="punctuation token">[</SPAN><SPAN class="number token">2</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">with</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>da<SPAN class="punctuation token">.</SPAN>UpdateCursor<SPAN class="punctuation token">(</SPAN>edit<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> FN_SHAPE<SPAN class="punctuation token">,</SPAN> wc<SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">as</SPAN> cur<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">for</SPAN> row <SPAN class="keyword token">in</SPAN> cur<SPAN class="punctuation token">:</SPAN> <SPAN class="comment token"># Update the undo edit stack</SPAN> edit_out <SPAN class="operator token">=</SPAN> list<SPAN class="punctuation token">(</SPAN>edit<SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">:</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">1</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN> edit_out<SPAN class="punctuation token">.</SPAN>append<SPAN class="punctuation token">(</SPAN>row<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN> undo_stack<SPAN class="punctuation token">.</SPAN>append<SPAN class="punctuation token">(</SPAN>edit_out<SPAN class="punctuation token">)</SPAN> <SPAN class="comment token"># Apply the edit</SPAN> row<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="operator token">=</SPAN> edit<SPAN class="punctuation token">[</SPAN><SPAN class="number token">3</SPAN><SPAN class="punctuation token">]</SPAN> cur<SPAN class="punctuation token">.</SPAN>updateRow<SPAN class="punctuation token">(</SPAN>row<SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">break</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>RefreshActiveView<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">class</SPAN> <SPAN class="token class-name">UndoEdits</SPAN><SPAN class="punctuation token">(</SPAN>object<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">def</SPAN> <SPAN class="token function">__init__</SPAN><SPAN class="punctuation token">(</SPAN>self<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN> self<SPAN class="punctuation token">.</SPAN>enabled <SPAN class="operator token">=</SPAN> <SPAN class="token boolean">True</SPAN> self<SPAN class="punctuation token">.</SPAN>checked <SPAN class="operator token">=</SPAN> <SPAN class="token boolean">False</SPAN> <SPAN class="keyword token">def</SPAN> <SPAN class="token function">onClick</SPAN><SPAN class="punctuation token">(</SPAN>self<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">global</SPAN> undo_stack <SPAN class="keyword token">global</SPAN> redo_stack <SPAN class="keyword token">if</SPAN> len<SPAN class="punctuation token">(</SPAN>undo_stack<SPAN class="punctuation token">)</SPAN> <SPAN class="operator token">></SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">:</SPAN> edit <SPAN class="operator token">=</SPAN> undo_stack<SPAN class="punctuation token">.</SPAN>pop<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>SelectLayerByAttribute_management<SPAN class="punctuation token">(</SPAN>edit<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'CLEAR_SELECTION'</SPAN><SPAN class="punctuation token">)</SPAN> wc <SPAN class="operator token">=</SPAN> <SPAN class="string token">'{} = {}'</SPAN><SPAN class="punctuation token">.</SPAN>format<SPAN class="punctuation token">(</SPAN>edit<SPAN class="punctuation token">[</SPAN><SPAN class="number token">1</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> edit<SPAN class="punctuation token">[</SPAN><SPAN class="number token">2</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">with</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>da<SPAN class="punctuation token">.</SPAN>UpdateCursor<SPAN class="punctuation token">(</SPAN>edit<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> FN_SHAPE<SPAN class="punctuation token">,</SPAN> wc<SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">as</SPAN> cur<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">for</SPAN> row <SPAN class="keyword token">in</SPAN> cur<SPAN class="punctuation token">:</SPAN> edit_out <SPAN class="operator token">=</SPAN> list<SPAN class="punctuation token">(</SPAN>edit<SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">:</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">1</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN> edit_out<SPAN class="punctuation token">.</SPAN>append<SPAN class="punctuation token">(</SPAN>row<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN> redo_stack<SPAN class="punctuation token">.</SPAN>append<SPAN class="punctuation token">(</SPAN>edit_out<SPAN class="punctuation token">)</SPAN> row<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="operator token">=</SPAN> edit<SPAN class="punctuation token">[</SPAN><SPAN class="number token">3</SPAN><SPAN class="punctuation token">]</SPAN> cur<SPAN class="punctuation token">.</SPAN>updateRow<SPAN class="punctuation token">(</SPAN>row<SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">break</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>RefreshActiveView<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">return</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
