Living Atlasアプリケーション:<\/STRONG>このリリースにより、新しいLiving Atlas of the World<\/A>ウェブアプリが利用可能になり、すべてのデータへのアクセスと強化されたユーザー体験を提供します。このウェブアプリは、Living Atlasコレクションの豊富なコンテンツを効果的に探索する方法を提供します。<\/P><\/P>Living Atlas of the Worldは、ArcGISの多くのコンポーネントの一つであり、数百のトピックに関する美しく権威ある地図を備えています。これは、人々、地球、生命に関連する多くのトピックの参照地図とテーマ地図を組み合わせています。Esriおよび数千の組織からの地図を探索し、ご自身のデータでそれらを豊かにして新しい地図や地図レイヤーを作成してください。<\/P><\/P>詳細についてはLiving Atlas機能概要<\/A>をご覧ください。<\/P><\/P><\/BODY><\/HTML>
<\/P>
詳細については
I see it for first time
amazing!
I am interested in hearing how users are incorporating the Living Atlas resources into their work. We are currently in the process of updating several of the natural resource layers so any feed back we can get will be useful as we build out these services.
Hmm where do we go to look at this the Disaster Relief looks interesting
nm I am silly and will read before I post
I really seems it awesome, didn't see it before. Thanks to being here with this stuff.
Thanks Kathryn for this!
Kathryn:
I am at your beautiful Living Atlas of the World website/gallery and have found content I would like to add to my map in ArcGIS Online. I am a member of ArcGIS Online for Organizations subscription. When logged into AGOL, I cannot see how to add Living Atlas content.
For instance, in the Living Atlas I see "USA Permitted Point Source Water Pollution", but in AGOL I tried to find this Living Atlas content via >Add >Search for Layers >ArcGIS Online and >Esri Map Layers - also >Add >Browse Esri Map Layers and I am unable to find this Living Atlas content.
As a member of an ArcGIS Online subscription, what is the best way to discover and use Living Atlas content?
Thank you.
OK - I found it. When using >Search for Layers >In: ArcGIS Online with key words "point source water" no correct search results were returned. When using keywords NPDES, the "USA Permitted Point Source Water Pollution" service was returned in the results. Interesting how particular keyword searches can be.
Joe
