Thanks Mark,
I ended up switching over to ArcReader. I didn't realize it was a free download and it enables someone to view an exact replica of the ArcMap document, which is all I wanted to do.
Kyle
Kyle,
The first field containing 'name' in the field name will be used, in the multiple features found list.
and yes 2 1/2 years later it still is not the ideal solution.
Mark
I'm using Explorer Desktop for the first time and am having the exact same issue mentioned in #2. Is this still a problem 2 1/2 years later?! I added a "Name" field to fix the pop-up title as recommended in other posts, but haven't came across anything to fix this problem with multiple items selected. It works fine in ArcMap.
