I am running spatial join tool, joining points to points : I wish to determine for each point in the target dataset the nearest feature in the join dataset, and to record that distance.
Both the join and the target dataset have the same (projected) coordinate system. They are both visible on the map.
Attachment#1 shows my table of contents. The target dataset is nswdb_2019q2_project. The join dataset is Chic Grocery Stores 2015.
The tool fails: see Attachment#2
Why does it fail? I have noticed this kind of failure before, intermittently, when the join dataset is in a group layer (as it is here).
When I move the Chic Grocery Stores 2015 layer outside the group layer, the join works.
I have edited this posting to use the terminology used by the tool. )2019-06-18 15:57 EST). There was no change to the substance of the problem.
