<layer> <name> Stream Gage </name> <url>http://rmgsc.cr.usgs.gov/ArcGIS/rest/services/nhss_usdata/MapServer/0</url> <expression>STAID = '[value]'</expression> <textsearchlabel>Search by Station ID [ Example: 03260100 ]:</textsearchlabel> <graphicalsearchlabel>Drag a box to identify the Stream Gage</graphicalsearchlabel> <fields>STAID, STANAME, STAGE, TIME,URL, CLASS</fields> <titlefield>Stream Gages</titlefield> <linkfield>URL</linkfield> </layer>
<?xml version="1.0" ?> <!-- //////////////////////////////////////////////////////////////////////////////// // // Copyright © 2008 - 2009 ESRI // // All rights reserved under the copyright laws of the United States. // You may freely redistribute and use this software, with or // without modification, provided you include the original copyright // and use restrictions. See use restrictions in the file: // <install location>/FlexViewer/License.txt // //////////////////////////////////////////////////////////////////////////////// --> <configuration> <layers> <layer> <name> Stream Gage </name> <url>http://rmgsc.cr.usgs.gov/ArcGIS/rest/services/nhss_usdata/MapServer/0</url> <expression>STAID = '[value]'</expression> <textsearchlabel>Search by Station ID [ Example: 03260100 ]:</textsearchlabel> <graphicalsearchlabel>Drag a box to identify the Stream Gage</graphicalsearchlabel> <fields>STAID, STANAME, STAGE, TIME,URL, CLASS</fields> <titlefield>Stream Gages</titlefield> <linkfield>URL</linkfield> </layer> </layers> <zoomscale>5000</zoomscale> </configuration>
<layer> <name> Stream Gage </name> <url>http://rmgsc.cr.usgs.gov/ArcGIS/rest/services/nhss_usdata/MapServer/0</url> <expression>STAID = '[value]'</expression> <textsearchlabel>Search by Station ID [ Example: 03260100 ]:</textsearchlabel> <graphicalsearchlabel>Drag a box to identify the Stream Gage</graphicalsearchlabel> <fields>STAID,STANAME,STAGE,TIME,URL,CLASS</fields> <titlefield>Stream Gages</titlefield> <linkfield>URL</linkfield> </layer>
link = value;
