<layer label="Surface Sea Water Velocity" type="wms" visible="true" visiblelayers="surface_sea_water_velocity" imageFormat="png32" alpha="0.6" skipgetcapabilities="true" url="http://hfrnet.ucsd.edu/thredds/wms/HFRNet/USWC/6km/hourly/RTV?service=WMS&srs=EPSG:4326"/>
<map wraparound180="true" initialextent="-130 30 -115 50" top="40"> <basemaps> <layer url="http://server.arcgisonline.com/ArcGIS/rest/services/ESRI_StreetMap_World_2D/MapServer" type="tiled" visible="true"/> </basemaps> <operationallayers> <layer label="Surface Sea Water Velocity" type="wms" visible="true" visiblelayers="surface_sea_water_velocity" imageFormat="png" alpha="0.6" skipgetcapabilities="true" url="http://hfrnet.ucsd.edu/thredds/wms/HFRNet/USWC/6km/hourly/RTV" version="1.1.1"/> </operationallayers> </map>
... ... <layer label="LINFOS" type="wms" visible="true" visiblelayers="LINFOS NRW" wkid="31466" imageformat="png" alpha="1" skipgetcapabilities="true" url="http://www.wms.nrw.de/umwelt/linfos?" version="1.1.1"/> </operationallayers>
That service supports many projections (see the section of the capabilities with the comment "All supported EPSG projections:") including 3857, which is equivalent to 102100.Try:<layer label="Marine" type="wms" visible="true" url="http://cmgds.marine.usgs.gov/geoserver/track/ows" skipgetcapabilities="true" wkid="3857" visiblelayers="lidar"/>
Does ArcGIS Viewer for Flex support identify WMS layers?
No, identify on WMS is not supported in neither the Flex API, nor the Flex Viewer.
FYI - That link requires people to log in to salesforce.
