I'm using ArcGIS Pro v 2.2.4 to digitize polygon features. I'm attempting to modify the edge of an adjacent polygon and wish for the connected edges and vertices to follow. I have the map topology selected from the Manage Edits group, yet the process fails. What am I missing here? Attachments show the two adjacent polygons.
On the Edit core tab, click the Modify command in the Features group to open the Modify Features pane. In the Modify Features pane, click the Reshape command under the Reshape group. In the Reshape pane, click Edge and then select a topological edge or node. Reshape the feature as you wish. All topologically shared features should update accordingly.
Reshape does not accomplish moving a shared node or vertex. In my image I show that I desire to move a vertex that is shared by multiple edges. When I move the vertex these shared edges do not follow.
I've used reshape to successfully reshape an edge, but that doesn't help me with the problem I've described.
Correct. If you want to move a topological node, the workflow may be found here. If you're looking to move a vertex that is shared, then click Vertices in the Reshape group, click Edge in the Edit Vertices pane, select an edge. All vertices are visible and can be move. Click the Green check on the toolbar located at the bottom of your map view to commit the edit. Then click Save.
Thanks. Yes, that does work so long as the vertex remains snapped along another edge. As soon as the vertex is no longer connected to the edge, the operation fails. Interesting that other vertices from other edges remain put. Using ArcMap the underlying vertices of both/all connected edges followed. Does that not happen with Pro?
There's an enhancement request for this workflow - not sure of it's status.
ENH-000114278 : ArcGIS Pro - Ability to grab a vertex(edit with Map topology) and able to move the edges at the same time which is share with the vertex to the new location.
Thank you for addressing my question. I'll look forward to the enhancement.
