http://sac-gisweb-01/arcgis/rest/services/MRCBaseMap/MapServer http://sac-gisweb-01/ArcGIS/rest/services/MRCBaseMap/MapServer
Bob, Sounds like you may be encountering a very common issue in the Identify widget. The issue is that Flex is a CaSe sensitive language. You have:http://sac-gisweb-01/arcgis/rest/services/MRCBaseMap/MapServer http://sac-gisweb-01/ArcGIS/rest/services/MRCBaseMap/MapServer the url one way in the main config.xml and another CaSe in the IdentifyWidget.xml. You need to have both the main config.xml urls and the IdentifyWidget urls Identical in CaSe.
