Great Info: Here's my work flow.1. Add Aerial or Feature Class2. Set Data Frame Properties a. Custom Extent - Current View b. Define Projection to Data Frame to (Mash w/ BING) - WGS 1984 Web Mercator (Auxiliary Sphere).3. Save MXD4. Publish MXD or MSD to AGS5. Cache Service a. Have tried many formats b. Aerial preferred JPEG or PNG32 c. 72,222 down to 1000 scales6. Anti - Aliasing a. Force and Best7. Add Service as Base Map in MPC8. Save AS Mobile Project directly to AGS9. Open in ArcGIS MobileIf I Add a Published Dynamic Operational Layer on top of Cached Aerial the Dynamic Service only appears.I've tested this with just the cached Aerial as well, it does not show.Please help and thank you
ログインすると、投稿したり、更新をフォローしたりできます。初めてですか?無料アカウントを登録しましょう。
