How do I update my existing Shortlist Story Map to the current release?
So what you would need to do,
Download the updated version and do everything you did to set it up initially.
Configure the app (add the app ID). Replace the old folder with the new one.
I would copy the old folder and rename it just in case the new app does not work right away.
I guess that's what confuses me. I did download it and put it on our server, but I do all of the content updating from ArcGIS.
How did you create the story map?
did you download it and put it on your own server?
Esri/shortlist-storytelling-template-js · GitHub
Or did you got to ArcGIS online and create one from there?
I'm sorry ... I'm a hack. Not sure what the difference is?
Are you using the developer or the AGOL version?
