<widget label="Search for HUCs" left="80" top="80" icon="../commonassets/images/m_search_right.png" config="../commonwidgets/eSearch/eSearchWidget_HUCs.xml" url="../commonwidgets/eSearch/eSearchWidget.swf"/>
You can create a commonwidgets directory and then change the widget xml and swf path to it. For example, I have an apps directory in which each of the FlexViewer apps sit. There is also a commonwidgets directory in the apps directory. Using the eSearch widget as an example, the code in the config file is: <widget label="Search for HUCs" left="80" top="80" icon="../commonassets/images/m_search_right.png" config="../commonwidgets/eSearch/eSearchWidget_HUCs.xml" url="../commonwidgets/eSearch/eSearchWidget.swf"/>
