When you add an image as the popup media, use the field name surrounded by curly braces to populate the URL property, like this.{Photo1}There is also a "+" button next to the input field that will list all of your fields and insert it. You can also have multiple fields that define the URL. For example, suppose I have one field that has an image name, "some.png" and another field that contains the base url to the image, "http://mserver.com/images/". You can concatenate the two fields like this.{BaseURL}{ImageName}Thanks,Mike
