<Window x:Class="ArcGISWpfApplication1.MainWindow" xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation" xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml" xmlns:esri="http://schemas.esri.com/arcgis/client/2009"> <Grid x:Name="LayoutRoot" > <Grid.Resources> <esri:SimpleFillSymbol x:Key="RedFillSymbol" Fill="Red" BorderBrush="Red" BorderThickness="1" /> </Grid.Resources> <!--Set the background color of the map control itself--> <esri:Map x:Name="MapControl" Background="Gray"> <esri:Map.Layers> <esri:GraphicsLayer> <esri:GraphicsLayer.Graphics> <esri:Graphic Symbol="{StaticResource RedFillSymbol}"> <esri:Polygon > <!--This could be bound to something else, this is straight from the SDK samples --> <esri:Polygon.Rings> <esri:PointCollection> <esri:MapPoint X="-10095589" Y="6616448" /> <esri:MapPoint X="-7797507" Y="6490526" /> <esri:MapPoint X="-8385145" Y="5147355" /> <esri:MapPoint X="-10641252" Y="5136861" /> <esri:MapPoint X="-10095589" Y="6616448" /> </esri:PointCollection> </esri:Polygon.Rings> </esri:Polygon> </esri:Graphic> </esri:GraphicsLayer.Graphics> </esri:GraphicsLayer> </esri:Map.Layers> </esri:Map> </Grid> </Window>
